PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys.
We compared price of PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys. across hundreds of online stores. We found PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys. in 1 store with lowest price $34.86 in ToolKing.com. For detailed price comparison of PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys. check table below.
Merchant | Price | - |
ToolKing.com | [show price] |
PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys. description from ToolKing.com
*** GO TO www.pac-audio.com FOR MORE INFORMATION **THIS IS A 4 CHANNEL LINE OUTPUT CONVERTER (OTHERS ARE 2 CHANNEL) .2-60 WATT/CHANNEL INPUTOUTPUT FOR AMPLIFIER TURN ON OR POWER ANTENNA W/1 SECOND DELAY.ALSO CONVERTS TO COMMON GROUND SPEAKERS IN OLDER CARS. The OEM-2 is the one-piece solution for replacing the radio or adding an amplifier to any factory system. This system is a 4 channel signal level converter with an internal remote trigger and a common ground speaker conversion circuitry. Adjusts up to 4 channels of signal input from 2 to 60 watts. The OEM-2 transformer isolates the input and output circuits, blocking DC noise and preventing snap, crackles and pops typical in other products. Sealed potentiometers prevent circuit-induced distortion and signal drift. Allows for conversion of floating ground head units to match common ground speakers systems. Provides an internal trigger to turn on a 2 amp/12 volt power line with a 1 second delay for an amplifier or power antenna. Deliver linear frequency response /-0.5 dB from 20 to 20,000 Hz, for unparalleled sound quality.
Customer review
I thing PAC PAC SOEM4 Sound Interface Premium for Upgrading Premium Car Sys. are seem as total top product in the market. As you can see popularity is high and also price 34.86 is very nice.
