Design House 522953 Dish Washer Air Gap Satin Nickel Finish
main picture
We compared price of Design House 522953 Dish Washer Air Gap Satin Nickel Finish across hundreds of online stores. We found Design House 522953 Dish Washer Air Gap Satin Nickel Finish in 1 store with lowest price $18.23 in UnbeatableSale.com. For detailed price comparison of Design House 522953 Dish Washer Air Gap Satin Nickel Finish check table below.
Merchant Price -
UnbeatableSale.com [show price]
Design House 522953 Dish Washer Air Gap Satin Nickel Finish description from UnbeatableSale.com
The Design House Dish Washer Air Gap prevents waste water from backing up into your dishwasher and contaminating your dishes. This air gap eliminates the risk of water contamination and is finished in satin nickel. There is a 5/8 in. and 7/8 in. inlet and the hose connection is not included. This product features a brass cap and plastic body.Dimensions - 1.81 x 1.81 x 1.81 in.Item Weight - 0.26 lbs.
Customer review
Is it just 18.23 for faucets? You have to get one! This Design House 522953 Dish Washer Air Gap Satin Nickel Finish is just amazing.
